agolebio
Feb 28, 2020Aspirant
Synology NAS 216+ not visible from Orbi Minirouter RBK40
Hi All, I am trying to connect Synology NAS 216+ into my home network without success. Orbi is set up as a router, there is nothing in between the ISP and Orbi. There are 3 devices hardwired (3 ...
agolebio
Feb 29, 2020Aspirant
Already raised a support case @ Netgear and Synology.
Feb 29, 2020Guru - Experienced User
One good way to tell about LAN activity, install a non manged non green ethernet Gb LAN switch behing the RBR. Then connect you LAN devices to this switch. Switch do have activity LED indications which are helpful.
agolebio wrote:Already raised a support case @ Netgear and Synology.
