agolebio
Feb 28, 2020Aspirant
Synology NAS 216+ not visible from Orbi Minirouter RBK40
Hi All, I am trying to connect Synology NAS 216+ into my home network without success. Orbi is set up as a router, there is nothing in between the ISP and Orbi. There are 3 devices hardwired (3 ...
CrimpOn
Mar 02, 2020Guru - Experienced User
agolebio wrote:I connected NAS directly to the PC having setup up DHCP server. Upon cable connection, LAN LED lights up on the DS216+.
DHCP server distributes addresses for PC and NAS. I can connect to the NAS to configure it, but no go when connected to Orbi.
Can you please describe more about how this test was performed? (Sort of selfish on my part. This may be something I want to try in the future. I do not see DHCP Server as a Windows feature that can be enabled from the Control Panel.)
Thanks
agolebio
Mar 03, 2020Aspirant
Sure,
Here you go...
We can use an open source software called DHCP server for Windows, it is not built into Windows. You have to download this software, install it and create a self-hosted DHCP server on your own computer to get IP addresses for your Windows system and connected NAS BOX. This will provide an IP address to both of them and the result you get; your NAS box starts communicating directly with your Windows PC using ethernet RJ45 LAN cable. This is applicable to any type of NAS box.
Here is a step by step guide including screenshots : How to connect Synology NAS directly to pc without router & external DHCP
