Samm426's avatar
Samm426
Follower
Mar 24, 2017
System Ad-On Satellite
Folks- I purchased the RBK50-100NAS and installed it.  AC3000 RBK50 and placed the router in the middle upper area.  I put the satellite by the upper far corner of the house and those two work fine.  I did purchase the add-on system RBS50 satellite.  However it is not working as good.  What am I doing wrong in my setup?
I put the router in the middle of the house one satellite on one end and the other on another end of the house.  I am getting good connection from the original package i bought but when I bought the add-on satellite, it is not working as good as the satellite that came with router in my first purchase.
  • Check there is no mismatch in Firmware version all three should be on same version.
  • so without the new sat turned on do you gave signal in the area from the router ? as it maybe the backhaul is not connecting well and you may need to move the new sat closer to the router
