Carnaged
Apr 21, 2017Tutor
Temperature range summerhouse + distance teething troubles
Hi all, I bought this system to improve my signal at one end of my house and hopefully give me some range into my back garden, I live in the UK in a 3 bedroom semi detached house so its not massi...
TheEther
Apr 21, 2017Guru
There are a few environmental conditions that are unfriendly to electronics:
- Extreme temperatures
- Extreme temperature swings
- High humidity
8 °C isn't necessarily extreme, but if the temperature goes from that to, say, 30 °C on a regular basis, then that will be bad. The temperature swing can cause solder joints to expand and contract to the point where they break. High humidity, well, I'm sure you know why moisture is bad.
Carnaged
Apr 22, 2017Tutor
Hi,
We might double from 8c at night to 16c but that would be on a very good day, winter would be troublesome due to minus temperatures but I could move the orbi inside in the winter as we wouldn't be in the garden much.
Ideally I would have the satellite in my house facing onto the garden but I could not seem to get any sort of decent results that way.
- TheEtherApr 22, 2017Guru
I'm guessing that your house is brick or concrete. Wi-Fi doesn't penetrate through such materials. Try placing the satellite near a window facing the garden.
