Saguarojoe's avatar
Saguarojoe
Tesla goes to sleep
My Tesla Model 3 has no problem connecting to orbi when the car is awake however Teslas go into a deep sleep mode when parked after a few minutes. It disappears from the network in that state. If Tesla sends an update will Orbi reconnect and send the update?
  • plemans's avatar
    Orbi isn't doing the reconnecting. The tesla is. If it wakes up, it'll connect (should). If you're selecting "update later" option when tesla sends you the update, the car should be waking to update at a later time.
    Again, thats all said with a should. If you google "tesla not waking" theres a ton of posts.
    • CrimpOn's avatar
      CrimpOn
      (Caveat: My experience may not be relevant to yours.)  My Nest thermostat disappears from the list of "Attached Devices" not because it is no longer connected, but because it has not sent/received data lately.  When I open the Nest app on my phone, the thermostat suddenly appears.  What I discovered was that the Nest has an "open connection" to the Nest Cloud (Amazon AWS).
      How about two tests:
      1. Try to ping the Tesla.  Does it respond?  If so, it is obviously connected.  This is not a "guaranteed test" because many devices (like my IP cameras) do not respond to ping.  So, if the Tesla does not respond to ping, then
      2. Telnet to the Orbi and enter this command:
        cat /proc/net/ip_conntrack | grep <ip of Tesla>
        Example: cat /proc/net/ip_conntrack | grep 192.168.1.55
        If the Tesla IP address shows up with an open connection to a cloud somewhere, then it should awaken and get the new software.
      • CrimpOn's avatar
        CrimpOn
        Not having a Tesla, this may be entirely "off the wall."  Do you have some sort of "Tesla App" on your phone that allows you to do goofy things, like "summon it", start up the heater, blink the lights, or something?  (not the keyfob remote, but an "app"?)
        If so, wait until it "goes to sleep" and then see if the app still works.
    • Saguarojoe's avatar
      Saguarojoe
      Sounds logical except the car isn’t checking for updates, the factory is letting the car know there is an update and downloads it for the owner to install on their schedule.
      Saguarojoe
      The waking issues come and go by vehicle and by the Tesla App release. I did a vehicle location with the app and it did show up connected. So perhaps Tesla can do that too.
      • CrimpOn's avatar
        CrimpOn
        Vehicle location may work over LTE.  Obviously, it's not much use if the vehicle can only be located when connected to the owner's WiFi.  (I would guess "Driveway" every time.)
