cmftblynu
Jan 19, 2018Star
The 2.1.2.18 nightmare
I won't bother going through how angry I am at Netgear for this firmware MESS (I already have in several posts) since they don't bother offering ANY customer support after they screw you out of your ...
Supertramp11
Jan 20, 2018Luminary
I upgraded my satellite and router manually, and have not had a single problem since then. Wireless devices nicely connect to the closest device and all it shown fine under connected devices. I’m doing a lot of high res music streaming through the house and – although I had disconnects and buffering issues prior to the 2.1.2.x, using the 2.1.2.10 (beta version) and now 2.1.2.18 all works great.
My nightmare ended and turned into a dream!
- LarryinNJJan 20, 2018Star
Gotta love someone with a Supertramp handle. Did you have any special methods of upgrading?? Aside from a lot of chatter here, a friend who also has an Orbi system said the upgrade took out his entire network, wired connections and all!
- Supertramp11Jan 21, 2018Luminary
No special upgrade methods. I'm not a router specialist, so followed the upgrade instructions to the letter: first the satellite then the router. That's all.
Oh, and before I forget: I'm using the Orbi mostly with its default settings. Maybe these are the only ones tested before a FW gets released?
- UnCapitanoJan 21, 2018Apprentice
I will say that I messed this upgrade up, based on not RTFM. I installed the upgraded firmware on router first and then the satellites, and had a whale of a time connecting to them afterwards. I had issues connecting with them in the SAME exact locations they have always been. So, I moved them within 10 feet of the router, forced the update, connected to them and then placed them back where they were originally.
My system has now been up for a couple of days with no major issues. I did have to factory reset the satellites, just to make sure I was doing things right.
