cmftblynu
Jan 19, 2018Star
The 2.1.2.18 nightmare
I won't bother going through how angry I am at Netgear for this firmware MESS (I already have in several posts) since they don't bother offering ANY customer support after they screw you out of your ...
wooties
Jan 19, 2018Star
Thank you so much for this. I am so frustrated with this flipping router. I'm working from home today and it's been rediculous. The reboots have kicked me off 2 conference calls and constantly interrupted work. I was just headed out to BestBuy now and will be purchasing Google wifi. I may try downgrading now that I have your instructions.. I can't believe how crappy their QA must be for these releases to be so bad.
jspringborn
Jan 21, 2018Initiate
Does anyone know how to check if NetGear is going to fix the 2.1.2.18 release? I am having issues with my wired ethernet backhaul since the upgrade. I guess the only solution at this point is back out the upgrade? Is there an easy way to do this, or do I need to just download the 2.1.2.16 version and manually upload it? And then I guess turn off automatic upgrades?
I am assuming waiting for a fix in the next couple of days is pointless. My satellites are useless without ethernet backhaul at this point as the distances are too far for wireless backhaul.
- JMU1998Jan 21, 2018Luminary
Any plans on a new Beta Firmware coming out soon?
