gordongekko's avatar
gordongekko
The wifi connections on my orbi system keeps dropping
Every 4 to 5 minutes, my orbi RBR50 AC3000  system diconnects and connects the wifi on both the 2,4ghz and the 5 ghz band. I have the newest sw installed on the router and satelite. I bougth my orbi system last week, it has been like this the whole time. I know i have the configuration in order, but i think this is a hw problem Netgear has on several of their products. I'm gonna return the product, no more netgear for me.
I have read lots of threads about the same problem in here, i have tried all the suggested solutions, none of the fixed my problem.
  • Unlikely to be a hardware problem. Use the paper clip method to do a full system reset of the Orbi.
    If you have the means to do a site survey using WiFi analyzer, I’d do that as well to ensure using the best available channel.
    • gordongekko's avatar
      gordongekko
      I did the paperclip thing, total reset the router and the satelite, and reconfigured everything, i still got the same issue. Wifi disconnects and reconnect every 4 to 5 minuttes. I have changed the channels on both 2,4ghz and 5 ghz, i have deactivated beamforming, MU-MIMO and fast roaming.The only advanced features i use is portforwarding and i have activated dynamic DNS since im running a server at home, because my ISP wont give a static ip.
      I forgot to mention when the Wifi drops, i stil got internet connection on my pc which is cabled.
      • gr8sho's avatar
        gr8sho
        Virtuoso
        I’ve seen something happen like that when the LAN side of the Orbi was using the same subnet address range as the host router. However logging into the management console would clear it up because the Orbi was able to detect the conflict. Symptom was same. Wireless devices wouldn’t connect reliably while wired seemed to work.
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
      gordongekko
      FW is V2.3.1.48 on both satelite and router, this is the newest.
      The Mfr is Alcatel lucent, the model is G-11G-P
      My hose is about 350 Sq Ft, its about 25 feet between the satellite(i have only one) and the router, diffrent floor though, but its a wired connection.
      I have tried channel 1, 6 and 11 and auto on the 2,4Ghz band, and any unused channels on the 5Ghz.
      I have 2 wifi neighbours, pretty close to my house, but their signals are weak in my house.
      I have tried earlier to enable and disable beamforming, mimo and wmm, didnt change a thing either way, still drops the wifi.
      But now i have done all the configuartions you suggested, the settings is saved and im gonna reboot both the satellite and the router, and i had wifi for about 6 minutes with this configuration.
      • FURRYe38's avatar
        25 feet maybe a bit too close, If you can try the RBS a bit farther out.
        If this still continues, try a full factory reset on the RBR and RBS and setup from scratch.
