Jeremyinsf
Dec 04, 2018Apprentice
TP-Link HS-105 wifi power plugs won't stay connected
One of my many, many problems with the 2.2.1.210 firmware is that my TP-Link HS-105 plugs drop off all the time and can't stay connected. They come and go, come and go. I have about a half dozen of...
Dec 05, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
I would contact the Mfr of the power plugs for additional help and information. Could an issue with these particular plugs.
