Bayamon62
Jul 20, 2018Guide
TP-link switch sg-108 wont connect to internet
After connecting my Orbi RBK33 ( rbr-40 router) my TP-Link TL-SG-108 ethernet switch will not connet to internet ,i have a ethernet cable from the orbi to the 8 port switch and nothing connected to i...
Jul 21, 2018Guru - Experienced User
Possible the this particular switch maybe the issue. I can't tell for sure if it's managed or not. Seems non mangages however maybe some of the other features this switch has could be causing problems.
https://www.tp-link.com/us/products/details/cat-4763_TL-SG108.html
Ensure lan cabling is good as well. Cat 6 recommended
I use these and my orbi works great:
- Bayamon62Jul 21, 2018Guide
Thanks for the reply, no doubt it is the switch , i can connet the cable that came with the router to my samsung smarthings hub and it will be online ,disconect the same cable connected to the unmanaged switch and reconnect the hub to the switch , nothing , the switch was working untili swapped routers so i doubt i went bad just by swapping routers , ill try to connet the switch to my laptop and see if i can figure out what is happening , Thanks .
- FURRYe38Jul 21, 2018Guru - Experienced User
Let us know if you find out anything...
- thombeJul 23, 2018Apprentice
I have the TL-SG-108E which is managed. (v3)
I read somewhere before (can't remember full details) but if you have the E managed model try disabling the IGMP Snooping.
I'm not currently using it with my Orbi as I'm experimenting wiht my previous Asus routers since they introduced AIMESH.
(1x DSL-AC68U and 2x RT-AC68U) if they are stable then I'll sell my Orbi, only as no need for both.
- BarryTregJul 23, 2018Apprentice
Hi I have this switch on my Orbi working fine. There was a bug in the switch'd firmware where it didn't always save your settings and would revert to defaults when rebooted. This got fixed by installing the latest version of the software. Maybe there's an issue for you there as well?
- FURRYe38Jul 23, 2018Guru - Experienced User
Let us know if you have had any progress.
