Bayamon62
Jul 20, 2018Guide
TP-link switch sg-108 wont connect to internet
After connecting my Orbi RBK33 ( rbr-40 router) my TP-Link TL-SG-108 ethernet switch will not connet to internet ,i have a ethernet cable from the orbi to the 8 port switch and nothing connected to i...
Bayamon62
Jul 21, 2018Guide
Thanks for the reply, no doubt it is the switch , i can connet the cable that came with the router to my samsung smarthings hub and it will be online ,disconect the same cable connected to the unmanaged switch and reconnect the hub to the switch , nothing , the switch was working untili swapped routers so i doubt i went bad just by swapping routers , ill try to connet the switch to my laptop and see if i can figure out what is happening , Thanks .
Jul 21, 2018Guru - Experienced User
Let us know if you find out anything...
