Ru058197's avatar
Ru058197
Tri-band Question
Quick question.  The specs say tri-band, however from what I am reading, one of these bands is dedicated to the router>satelite communication (from what I understand, that is to achieve perfromance without degradation).  So, if I got that right, am I only going to have access to two bands?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Ru058197
    The Orbi Wi-Fi system delivers 3 independent radios including one 2.4GHz band and two 5GHz bands for 802.1a/b/g/n/ac wireless devices. Smart Connect intelligently selects the best Wi-Fi band for each dual-band device to optimize connection speed and performance based on that device’s speed and performance capabilities.
    DarrenM
  • Tri-band?  It is dual band with 3 radios. one radio for 2.4GHz band, two radios for 5GHz band split in two,  lower half and higher half.
  • hi Ru
    to answer you question
    you would have dual band ether way as ( apart from the new tp link 7200 ) no current routers are actually tri band as 2 of the transmissions are on the same band
    however to the answe you actually want
    you are corrdect there are only 1 transmission on each band you have access to , one on 2.4 gig and one on 5 gig , the second transmission on 5 gig is used specifically and exclusivly for the backhaul connection from sat to router
    thus what you have access to is
    1 x 2,4 gig 400M transmission
    and
    1 x 5 gig 867M transmission
    this is per device
    so the router transmits 1 x 5 gig and 1 x 2.4 gig and the sat transmits 1 x 5 gig and 1 x 2.4 gig
    both with the same ssid name
    so your assumption is correct , you have no access to the third transmission as its specifically for the backhaul
    pete
    • TheEther's avatar
      TheEther
      Guru
      peteytesting wrote:
      hi Ru
      The current routers marketed as tri-band can transmit simultaneously at 2.4 GHz and two of the following 5 GHz bands: U-NII-1 (5.17-5.25 GHz), U-NII-2A (5.25-5.32 GHz), U-NII-2C (5.5-5.72 GHz), and U-NII-3(5.745-5.835 GHz).  IMO, it's fair to consider these routers tri-band.
      But it is true that the Orbi only has two user-facing bands.  The third is used for a dedicated connection between the base and satellites, so while it's not technically wrong to call the Orbi tri-band, it is a bit misleading.
      • peteytesting's avatar
        peteytesting
        Hero
        i agree that it could be misleading along with the reviews that have called it a mesh system as at this stage its not , you could also say its misleading to say its got speeds up to 3 gig when in reality the fastest you can sync to it is 867M
        its advertising blurb and its why users really have to do their homework before blindly buying anything including the orbi system
        pete
