AllOuttaBbleGum
Jan 14, 2021Guide
True Factory Reset Sequence - The Real Way to Reset your Orbi
Posting this to help other frustrated Orbi owners.
Finding a solution to this was very hard. I suspect a lot of "dead" hardware just needs to be reset properly. I bought a used Orbi RBR50 and RBS50 to add my existing Orbi netwoerk which I bought new a few years ago. I did the commonly-advised "hold the reset button down until the LED next to it flashes orange". Nope, nope, nope. The right way is called a "30-30-30 reset" and apparently is an industry standard that works on most routers (kind of like holding a PC power button down for four seconds will shut them all off). As follows:
1. Power up the device and wait about a minute for it to finish booting.
2. Using a bent paper clip, press down the reset pin for 30 seconds, and keep holding it down. Ignore anything else going on.
3. While still holding it down, unplug the power connector for 30 seconds, and keep holding the pin down.
4. While still holding the pin down, plug the power cord back in and wait 30 seconds.
Your device is now "out of the box".
Worked for me twice on two unreachable, and/or badly behaving devices.
Sort By
A reset shouldn't be needed if it's new and out of the box from the Mfr. Only a 15 second press is needed for any factory button press. Possible the unit was used prior and was 3rd party resealed to make it look new in box as well. Seen alot of re-sellers repackage items.
Good Luck.
Yes, it was used, as I mentioned.
What FW version came loaded on it?
- oalsie33Aspirant
After you configure the modem for modem mode, you must energy OFF the modem for 1 minute then again on then reset the RBR and stroll via the setup wizard page. I might even ask for extra assist from your ISP about your modem to make sure it's configured efficiently for modem only mode.
