LM_HK's avatar
LM_HK
Trusted devices are blocked
The following is my configuration:
  • SSID broadcast turn off
  • Access Control turned on and have all new devices blocked from connecting
  • All my own devices are added on the "allowed" list.
The above have been working fine since the system was set up months ago.  However, since a couple of weeks ago, a few devices were some times "blocked" automatically.   I manually turned it on but they was turned off again quickly somehow.
I installed Netgear Arlo recently and I am wondering if it is the cause of the problem.
Pls help.
1 Reply
  • FURRYe38's avatar
    What FW is currently loaded? What FW updated recently?
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
    Might try a factory reset on the Orbi router and setup from scratch and re-configure access controls. I would set up IP address reservations as well for devices that you are trying to control.
