jvetro
Dec 12, 2020Tutor
Trying to Set RBK50 in AP Mode with wired backhaul and have a few issues
I have been going at this for a couple of days now and I cannot seem to get this working. I am trying to setup my Orbi system in AP mode with a wired backhaul. 1st issue) I can get the Orbi in ...
- Dec 15, 2020
You need to downgrade to v16 if you want ethernet backhaul to work:
Dec 12, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
Be sure your using good quality LAN cable. CAT6 is recommended.
jvetro
Dec 12, 2020Tutor
TP-Link TL-SG116
BTW, I was never able to see the web gui indicate wired backhaul even connected directly to the AP with the cable provided by Netgear.
- FURRYe38Dec 12, 2020Guru - Experienced User
So first off,
Ensure the RBS is using same version of FW and RBR.
Wirelessly connect the RBS to the RBR to ensure it connects then. If that happens, then use a good quality LAN cable and connect the RBS to the back of the RBR to see if it will connect. Top ring should turn BLUE. Status on the RBR may take a bit longer to update. Give it a few minutes.
IF the RBS gets connected wired, and status shows, then turn OFF the RBS then connect to the remote location. If the RBS fails to connect after the switch, then try a different switch. Your current switch has some green ethernet features that causes some problems for Orbi systems.
- jvetroDec 12, 2020TutorI will try a few things and try to bypass the switch for the wired backhaul.
- jvetroDec 12, 2020TutorI reset everything to factory default. I have only my laptop and the 2 Orbi's connected in my setup. The RBR50 is on Router mode connected to the RBS50 using wireless backhaul. I then connected a Cat6 cable directly from the RBS to the RBR, and the connection type on the web gui still shows 5g connection type. I would like to have this working first before putting in AP mode with the rest of my network.
