scottandria
Jun 15, 2017Aspirant
Trying to Setup Home WiFI with Network Monitoring (Domotz Box)
I am looking into the Netgear Orbi setup for my house (approximately 4,500 sq. foot house with 3 floors). I am thinking about getting the Orbi routers and putting the router on the main floor and on...
scottandria
Thanks for the reply.
The Domotz box is not a router. It is stritly a network monitoring device. Do you know if Orbi publishes information (MAC and IP) about the devices that connect to it?
As far as the setup is concerned, both satelites would connect to the router on the main level. Since I will have 3 units--router and two satelites--should I go with the AC3000 or the AC2200?
rhester72
Jun 15, 2017Virtuoso
No router in the world 'publishes' such information - Domotz monitors networks the same way everyone else does, via ping (is it reachable?) and SNMP (what can I learn about it, in terms of interfaces, throughput, and other health metrics)?
I don't believe Orbi allows collection of SNMP data from it, so what you'll get from the Orbi itself is extremely limited. Domotz also monitors -any- device it can find on the network, so I'm not sure it's that much of a loss if you can't get detailed stats from Orbi.
Rodney
- Retired_MemberJun 15, 2017
Domotz works fine with Orbi.
- scottandriaJun 15, 2017Aspirant
Great to hear. Are you currently setup to use Orbi and Demotz?
Domotz integrates easily with the Luxul AC-3100 Router. Users are able to give names to the devices. So, for instance if a parent has a kid on Netflix at 1:00 AM in the morning, the parent can use Domotz to turn off internet access for a specific device (i.e., to make their kid go to sleep)!
I cannot find a lot of information about the Luxul router, so I would prefer to use the Orbi setup.
Domotz does not integrate with Orbi at all. It works fine, but in no way integrates. Giving devices names is supported by Orbi, but is not synced with Domotz. I recommend you use ScreenTime for mobile devices and Windows 10 Family Settings for time limits.
I use Domotz to monitor the devices on my network, but not any sort of control over them.
