bardaravine
Sep 30, 2017Aspirant
Tunnelblick VPN Client on a Mac does not change the public IP
Public IP address not changing when I log into the VPN. I would like to browse the internet from this VPN, but tunnelblick client isn't routing all my internet traffic through my house. Running Mac O...
DexterJB
Oct 04, 2017NETGEAR Moderator
Hi bardaravine,
1. What is the firmware version of your router?
2. What version of Tunnelblick do you have installed?
3. Do you have the option set to "All sites on the Internet & Home Network", "Home Network only", or "Auto"?
Dexter
Community Team
DexterJB
Oct 10, 2017NETGEAR Moderator
Hi bardaravine,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- bardaravineOct 10, 2017Aspirant
I've since returned the router and exchanged it for an Asus. Current router is working like a champ. Who knows what I did wrong.
Thanks for reaching out.
- RThomas1975Jan 26, 2018Aspirant
I am having exactly the same problem. Seems to connect but will not grab the host IP. And yes, I did select "All sites on the Internet & Home Network."
