Gorlum_IL's avatar
Gorlum_IL
Turn off LEDs on RBK23
How I can rurn off leds on RBK23 satellites?
  • Which LED's? All ring LED's will light briefly during setup or after satellite connectivity's status change for few seconds and will then turn off, so in stable condition all ring LED's will be off.
    • Gorlum_IL's avatar
      Gorlum_IL
      All leds. I have one satellite in my bedroom, and led on all night.
      • ekhalil's avatar
        ekhalil
        Master
        There are two LED's on Orbi, please see below:
        1. Ring LED is off in normal operation mode, so you should have it off during night unless there are disturbances in the network. Do you have the Ring LED on at any time? Which color?
        2. Power LED is on as long power is on. You can turn it off only by powering off the node! :)
