SnorkyMN's avatar
SnorkyMN
Turn off WiFi on RBR50
Hello,
Due to a new internet provider for my community, which is putting in WiFi in every unit, I don't need to use my Orbi anymore for Wifi, but I still want to use it as a switch/hub for my hardwired connections.   I looked online for answers how to turn off wifi, but every answer I tried seemed to have options that I couldn't access.  Like turning on Telnet and logging in and running commands, or going into advanced setup and just clicking enable or disable.. none of these things seem to be an option on my Orbi.
Does someone know how to disable WiFi on this Model?    It's on firmware version V2.7.4.24.
-Trent
  • plemans's avatar
    You can turn off the ssid broadcast but it doesn't actually disable the radio.
    So its not much benefit.
    You might just wait and see how your apartments router works. The orbi might provide better coverage.
    • SnorkyMN's avatar
      SnorkyMN
      They have to build a mesh, using the Amazon Eero, so my Orbi Mesh is no longer needed.   And I didn't want the 2 additional wifi signals so close to where my wife and I are working.    But if I can't figure it out, I'll just have to try to sell the base and Satellite and use switch.
      • CrimpOn's avatar
        CrimpOn
        Might be a good idea to "wait and see" how this plan to mesh a lot of units with eero works out.
        The more paranoid of us would be a bit wary of sharing a network with LOTS of strangers.
