MarkLOrbi's avatar
Oct 01, 2018
Turned off dhcp, now I can't login to router
I turned off dhcp on my orbi, after power cycling I can't log back in. Orbi is connected to my modem/router and the modem/router says orbi has address of 192.168.1.64. My desktop is connected to mode...
  • MarkLOrbi's avatar
    MarkLOrbi
    Oct 01, 2018
    Did factory reset and put it in AP mode. It provides both wireless and guest wireless, working good. Thanks for the help.
