Retired_Member
Apr 09, 2017Two systems, one network
I have an older home, that is split level (5 levels) and very long. The ceilings and walls are rock lathe and plaster (1" thick). Currently I have an Orbi system, but I am having signal issues w...
Retired_Member
Apr 11, 2017Hi Darren,
Wouldn't I be able to use the same SSID?
DarrenM
Apr 12, 2017Sr. NETGEAR Moderator
You can but the devices will not automatically switch to each network.
DarrenM
