GWild's avatar
GWild
Guide
Feb 16, 2021
Typical Speedtest Result Expectations for CBK40 Kit
Anyone have FIRSTHAND knowlege of the actual throughput for a CBR40 - RBS20 via wifi?
CPU - 1GbT (wired) - RBS20 ~~~ BACKHAUL ~~~ CBR40 - 1Gb CABLE
It's essentially using the RBS20 as a bridge to the CBR40. All the specs indicate the wireless cap should be 2.2Gbps (or 866Mbps if you assume single channel) ... I am looking for anyone who has actually tested the set.
I'm not seeing anywhere near that level of performance...
  • Heres what I get with my wired PC connected to a ASUS GT-AX11000 in wireless bridge mode connected to my Orbi 850 series connected to a CM1200 modem:
    This is about max speed I generally see with most any of my 1Gb LAN devices.
  • FURRYe38's avatar
    You not see anything near 900mpbs on 5Ghz wifi. Max speeds maybe around 300-400Mpbs, depending upon devices design and support. Nature of the beast.
    Wired you should seen near 700-800mbps or over on wired LAN PC tests. The CBR40 is DOCSIS 3.0. Most ISPs now days require DOCSIS 3.1. The CBR40 is capable of near 900Mpbs however depends on what your ISPs requires as well. I had the CBR40 when it first came out and had it on a 1Gb connection for a trial period with my ISP and I was about to see 800 to higher 800mbps speed range most of the time.
    My ISP now requires DOCSIS 3.1 modems so I have move to that platform.
    • GWild's avatar
      GWild
      Guide
      Wow Furry -- I nearly always get 1Gbps on 1Gbps wired networks. It is why they spec them as 1Gb networks. Sorry to hear you have had such poor luck with wired connection quality. The CBR40/RBS40 pair is spec'd 866 on 5G channels, seeing ~500 line of sight means it is not meeting spec. You were seeing even less; ouch. But I am also seeing only 500M over a wired connection on the CBR40 -- half of what it is spec'd to do. So I see a trend here.  It makes upgrading to the same brand less than warranted -- if the Orbi can't even meet its own spec, why would I want to spend money on another Orbi?  Sigh.
      ps: I'm on a 10Gb network - my hardware keeps up, lol, mostly. Hard to keep a 10G pipe full in a small network.
      • FURRYe38's avatar
        If your seeing 500Mbps on wireless then this would be with in the spec. Again, wireless will not ever see anything near 900mpbs on 5Ghz AC. The connection rate of 866Mbps is only a connection rate between the wirless devices, if it supports that rate and the RBR/RBS. This differs from actual speed thru put. Don't confuse them. Connection rate differs from actual bandwidth:
        https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
        Also antenna support on wirless devices will impact and limit how wireless speed performances work. 2x2 will cap out at around 400-500Mpbs. 4x4 and higher allows for higher speeds. My iphone 12 max is 2x2 supporting, though AX mode supporting, it's stil only max's out around 700mpbs on my Orbi AX system.
        Make no mistake, the CBR40 when I had it was working well at the time. This was back in 2017. Speeds were wired and on a 1Gb network, worked just fine.
        10Gb, well thats fine but thats only on the LAN side. If you have that then cool. but your bottle neck will be any router or modem with 1000Mpbs WAN and LAN ports which the CBR was only designed for. NG has a few 2.5Gb WAN port supporting devices. 10Gb hasn't been seen much yet on a consumer level and isn't quite fully appeared yet. Seems like some mfrs are slowly graduating getting pasted 1Gb and just breaking into 2.5Gb rates. Not alot of consumer class devices can handle 10Gb bandwdith. There is HW considerations to take in when dealing with 10Gb. Thats a spendy speed to put in when you can't fully take advantage of it. Hope you can.
