GWild's avatar
GWild
Guide
Feb 16, 2021
Typical Speedtest Result Expectations for CBK40 Kit
Anyone have FIRSTHAND knowlege of the actual throughput for a CBR40 - RBS20 via wifi?   CPU - 1GbT (wired) - RBS20 ~~~ BACKHAUL ~~~ CBR40 - 1Gb CABLE   It's essentially using the RBS20 as a bridg...
  • FURRYe38's avatar
    Heres what I get with my wired PC connected to a ASUS GT-AX11000 in wireless bridge mode connected to my Orbi 850 series connected to a CM1200 modem:
    This is about max speed I generally see with most any of my 1Gb LAN devices.
