Fscottwill
Sep 26, 2018Guide
U-Verse, Orbi and CUJO
I currently have a U-Verse gateway in “bridge” mode with my Orbi(s) doing all the routing. I just ordered a CUJO firewall. Did I mess up? What is the right way to combine these three devices int...
- Sep 26, 2018
Config 1 is my configuration that is working great: ( I have to inject a EdgeRouter X in the middle to make it work)
Config 1:
Connect U-Verse to EdgeRouter X eth0 ($35 from Amazon) configured as WLAN+1LAN
Connect Cujo Bottom port to EdgeRouter X eth1
Connect Cujo upper port to ORBI WAN
Open Cujo App and change mode to BRIDGE mode (Not DHCP)
Change ORBI to AP Mode
Now All traffic will go through CUJO and all routing will be done through EdgeRouter X (which is think is superior in routing than ORBI)
Just beware, DO NOT USE EDGEROUTER OTHER PORTS. all the other devices that are connected to remaining of the Edgerouter X ports will not be protected by CUJO. Keep in mind whatever connected to CUJO upper port in BRIDGE mode are protected including all sub devices and chain of switches e.g everything will be protected in the following config: CUJO Upper Port connected to Switch 1 <-> Switch 2 <-> Switch 3 <-> Router X <-> switch 4 ....... n
Config 2:
You could totally avoid edgerouter X enabling DHCP mode in CUJO and the configuration would be:
Connect U-Verse to ORBI WAN
Connect CUJO Bottom Port to ORBI LAN Port
Enable DHCP Mode in CUJO
The disadvantage of config 2 is that you have very limited options for port forwarding and all the advance network configuration. CUJO has very limited capability to open port in DHCP mode. If you can live with that, Config 2 would be your best bet.
aani75
Sep 26, 2018Apprentice
Config 1:
Config 2:
Fscottwill
Sep 29, 2018Guide
I used your config 1 and it works perfectly.
Thank you very much
