AltSB
May 14, 2025Aspirant
Unable to Access Orbi RBK23 Admin Interface (192.168.1.1 reachable but Web UI not loading)
Hello everyone, I am experiencing an issue with my Netgear Orbi RBK23 router where the admin interface is completely inaccessible, despite the device being online and reachable. Problem Symptoms:...
AltSB
Thank you for the guidance - I have followed that procedure, but unfortunately no change.
In between I have noticed other side effect. I am using Home Assistant and it recently also started to fail to connect to the netgear device (used for presence detection while phones are connected to wifi, which now no longer works).
I believe something is messed up on the authentication layer.
May 14, 2025Guru - Experienced User
Please try a factory reset and setup from scratch with a PC and web browser:
https://community.netgear.com/kb/en-orbi-knowledge-sharing/orbi-systems-manual-factory-reset-process/2456340
