JWHK
Oct 25, 2017Aspirant
Unable to add satellite to Orbi (RBK53)
As I live in a 4-storey house, I bought RBK53 (which includes 1 route and 2 satellites) plus one RBS50, that is total of 1 router plus 3 satellites; but I am only able to connect/sync 2 of the 3 sate...
JWHK
Additional info: I tried the method as suggested in one of the Community message streams, but it did not seem to work for me... That is: "disconnected one of the satellites that did work, then sync up the third (that did not work), then brought the 2nd one back online". Is it possibly because I am using RBK53 instead of RBK50? Or any setting I need to make on the router before connecting the 3rd satellite? Anyone please kindly advise the method to connect the 3rd satellite to Orbi router please. Thank you.
DarrenM
Oct 27, 2017Sr. NETGEAR Moderator
You may want to contact support if the satellite will not connect with the normal method.
http://www.netgear.com/support/contact.aspx
DarrenM
