Liverpoolfan
Aug 21, 2020Aspirant
Unable to connect Orbi to Fiber Optic via pass through issue/CBK40
Hello, we recently upgraded to faster speeds with ATT fiber optic, and I would like to continue using my Orbi System. I contacted att and they enabled the pass through, and it shows on att that the n...
Mstrbig
Aug 21, 2020Master
First off Coax has nothing to do with orbi. Are you sure you are not mistakenly accessing the router. Are you using the app or WEB GUI at orbilogon.com.
- LiverpoolfanAug 21, 2020AspirantHey thanks for replying! I’m doing the setup via the Orbi App. I’m connecting the modem for sure since it’s taking the QR code I don’t think the setup would access the router? I mentioned coax since it’s one of the steps.
