willjeeler
Aug 01, 2021Aspirant
Unable to install Orbi
Just bought Orbi Ultra Performance Mesh WiFI System - AX6000 - 2 pack - RBK 852. Followed the installation directions. Unable to connect to network. I use AT&T fiber. I have a Sonos system...
willjeeler
Looks like the modem is ATT - does not have another mfr name and model number.
How do I check the firmware?
Router is also a ATT BGW210.
What is RBR you are referring to?
Sorry, I'm not a super tech person at all. But I can usually find my way through things.
I'm using a MacBook Pro and don't have the correct cord to wire direct into modem or router.
Appreciate the quick response!
Aug 01, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
RBR = The Orbi router unit. RBS = Satellite units.
There are inexspensive USB C to ethernet adapters available.
- willjeelerAug 01, 2021Aspirant
Ok. I'll have to call AT&T. thank you.
- FURRYe38Aug 01, 2021Guru - Experienced User
Good Luck.
- willjeelerAug 02, 2021Aspirant
Thanks.
Have decided to return it and go with another brand.
If I had known the installation would be that complicated, I wouldn't have bought it.
Appreciate your time.
