mast3rof0's avatar
mast3rof0
Initiate
Oct 10, 2019
Unable to install RBS40V
I have an RBR50 installed with three satellites. I recently purchased a new RBS40V-200 to replace one of my existing satellites but I cannot get it paired with the router. Since the RBR only supports...
  • mast3rof0's avatar
    Oct 10, 2019
    Found solution on  this thread
    Turns out the 40V-200 is in extender mode by default. It needs to be converted to Orbi mode, but these details and instructions are not included with the  device.
    Instructions can be found here
