marcin_olo
Oct 19, 2020Follower
Unable to set static IP on RBR40
Hi, I'm using Orbi RBR40 for some time and after initial setup there was no issue at all. Until now when I wanted to change router's IP address to static address. And now regardless what I set (s...
Oct 19, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Build in router here by chance? If so, this may cause the 10.0.0.1 address to be seen on the RBR as the upstream router also maybe using 192.168.1.1...
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
