Pistol_451
Aug 02, 2026Aspirant
Unbrick an RBR40
Hi, hoping someone might be able to help me unbrick an unresponsive Orbi RBR40. It just decided to up and die on me, the second one to do so (the only reason I got another one was I found one very ch...
Aug 03, 2026Guru - Experienced User
Two years later and your still trying to fix that?
That code would be an internal code for OpenWRT FW. You'd have to ask them on what that means.
If you need another RBR, try looking at places like ebay for shopgoodwill for good used units and easier to get something running if you really want another RBR40 thats now EoL.
Maybe time to upgrade to something new as well.
Good Luck.
