Pistol_451
Aug 02, 2026Aspirant
Unbrick an RBR40
Hi, hoping someone might be able to help me unbrick an unresponsive Orbi RBR40. It just decided to up and die on me, the second one to do so (the only reason I got another one was I found one very ch...
Pistol_451
Aug 03, 2026Aspirant
Ha, not quite - I binned the original one and replaced it with another off ebay. Lasted two years before the second one also died, figured I'd try again and the serial adapter was so cheap it was worth a shot.
It does indeed look as though that error is fairly terminal - I found nothing Orbi specific, but as you say there was something on the OpenWRT forums which indicates the RBR40 isn't even getting as far as U-boot completion, and so manually updating the firmware isn't going to be an option. Time to bin this device as well...
The sad thing is, although I swore I'd never get another, it's infinitely cheaper to pick up another RBR than it is to upgrade, and if I get another 2 years out of the next one... I must be a glutton for punishment :(
- FURRYe38Aug 03, 2026Guru - Experienced User
Maybe go with something newer generation, AX or AXE or BE series.
IF the 40 series failing at a particular time frame, I'd move into something newer generation. I still have my 850 series from 2019. Working great.
Good Luck.
