nosmoke
Apr 16, 2017Aspirant
Update before install
Hello, I want the Orbi router and satellite to be fully updated firmware-wise prior to the tech arriving for our new FIOS installation. When the Orbis arrive to my house, can I update the firmware ...
- Apr 16, 2017
Yes, you can update the firmware first if you want.
VE6CGX
Apr 16, 2017Master
My idea is alway try whatever I am installing just as is out of the box to make sure it is working. Then I'd update firmware or whatever
I want to do with the it. If firmware is updated right off the bat and gets into trouble, it'll create confusion regarding the cause of the
problem.
