shankara
Mar 20, 2021Tutor
Update firmware via app or web?
Hello: I use the Orbi RBR50 router with the RBS50 satellite at my home here in India. The Orbi app on my iPhone says that I am using firmware version V2.3.5.30IN. The support web site says that the current firmware version as of 20 March 2021 is 2.7.2.104. But when I try to find this version using the Orbi app on my iPhone by tapping on the "Check for Updates" button, the app times out and gives me a "Firmware Check Error". So since the app is clearly not working for me, is it safe if I update the firmware manually from the web site? Thanks for any comments!
- vajimMaster
IF you feel like you need to update your firmware use the pc login.
FYI...There have been numerous complaints about 2.7.2.104. You may want to hold off.
I usually recommend people upgrade over a hardwired connection.
Its not supposed to make a difference as the upgrade process is supposed to be hosted on the router/satellites.
But usually when I see corrupt firmware issues, its when done over wireless or using the app.
So I recommend doing it hardwired into the router
- shankaraTutor
Thanks! But I am also worried that because my Orbi app does not show the latest firmware version, perhaps I am not meant to install it for some reason. Are firmware updates restricted to certain regions, for example.
- shankaraTutor
What are the most reliable instructions for how to update firmware from my computer? (I use a Mac.) Thanks!
- vajimMaster
shankara wrote:What are the most reliable instructions for how to update firmware from my computer? (I use a Mac.) Thanks!
https://kb.netgear.com/000058278/How-do-I-update-the-firmware-of-my-Orbi-WiFi-System
is your system not working or unstable?
