adambean
Oct 04, 2017Luminary
Updating Orbi firmware questions/problems | running in AP
Hey all, When I look at the firmware update section of Orbi, I only see the Router (RBR50); however, I have two satellites (RBS50) attached as well, they do not show. Further, it shows my RBR50 i...
adambean
Yep, have to connect to each device by IP and perform updates manually. Not the worst, but a bit of a PITA.
I see that you can set the IP of the router, but can you not do so on the satellites?
Thanks
- adambeanOct 04, 2017Luminary
Well that's fun, updated sat1, no issue. Updated sat2 and it's not coming back online. These things are so flakey ... it's why I bailed the first time. Wanted to give them another shot, quickly losing faith.
adambean wrote:Well that's fun, updated sat1, no issue. Updated sat2 and it's not coming back online. These things are so flakey ... it's why I bailed the first time. Wanted to give them another shot, quickly losing faith.
Good call. Will try that after I get sat2 operable again. Stuck with a magenta light after upgrade. Just did a factory reset ... fun.
So i started a new thread about the bad firmware/sat issue, that isn't showing up on the forum list, nor can I reply to it?
https://community.netgear.com/t5/Orbi/Magenta-lite-on-satellite-after-firmware-upgrade/td-p/1385855
