adambean
Oct 04, 2017Luminary
Updating Orbi firmware questions/problems | running in AP
Hey all, When I look at the firmware update section of Orbi, I only see the Router (RBR50); however, I have two satellites (RBS50) attached as well, they do not show. Further, it shows my RBR50 i...
adambean
Yep, have to connect to each device by IP and perform updates manually. Not the worst, but a bit of a PITA.
I see that you can set the IP of the router, but can you not do so on the satellites?
Thanks
