worldofshayan
Jan 13, 2018Apprentice
Upload speeds very slow on Orbi via Wifi - On ethernet its at 100%- why?
So I've just got a new 200mbps dedicated fibre connection (clean full signal) and am using my Orbi Wifi system. On the Router Speedtest via the Orbi app (the speedtest of the router and the connectio...
- Jan 16, 2018I ended up flogging Netgear Orbi and buying the Zyxel Multy X. Way way better!!!
wase4711
Jan 13, 2018Luminary
are you in router mode or AP mode?
funny, i get faster upload speeds on wifi than download speeds..
- worldofshayanJan 13, 2018Apprentice
I'm in Router mode.
- wase4711Jan 13, 2018Luminary
are you connected directly to your modem, or connected through a switch or another router?
- worldofshayanJan 13, 2018ApprenticeDirectly connnected. As stated the direct router speed test through the app is very good. It’s just on wifi the upload speed is very poor.
