worldofshayan's avatar
worldofshayan
Apprentice
Jan 13, 2018
Upload speeds very slow on Orbi via Wifi - On ethernet its at 100%- why?
So I've just got a new 200mbps dedicated fibre connection (clean full signal) and am using my Orbi Wifi system. On the Router Speedtest via the Orbi app (the speedtest of the router and the connectio...
  • worldofshayan's avatar
    worldofshayan
    Jan 16, 2018
    I ended up flogging Netgear Orbi and buying the Zyxel Multy X. Way way better!!!
