worldofshayan
Jan 13, 2018Apprentice
Upload speeds very slow on Orbi via Wifi - On ethernet its at 100%- why?
So I've just got a new 200mbps dedicated fibre connection (clean full signal) and am using my Orbi Wifi system. On the Router Speedtest via the Orbi app (the speedtest of the router and the connectio...
- Jan 16, 2018I ended up flogging Netgear Orbi and buying the Zyxel Multy X. Way way better!!!
wase4711
Jan 14, 2018Luminary
I've tried all of those, and the Ubiquiti hd mest as well;
Eero is very stable, but not as fast speeds as this Orbi pro
If the Orbi Pro doesnt work for you, then definately the Eero Pro second gen shoudl be your second choice
worldofshayan
Jan 14, 2018Apprentice
I have the normal orbi. Not the pro. I have a 200mbps connection. I'm getting from 20-200 with the orbi and the main router speed is showing constantly good speeds (see speed test of main router to internet attached - excellent but wifi is dismal by comparison!). Even if the eero pro gives me 150 up and down I'll be ELATED! AS long as the dam thing works!!!
- CandaceWaltonFeb 10, 2018Aspirant
Mine too. I'm contemplating returning my new Orbi. It is too hard to figure otu how to fix this issue. I'm at .11 mbps upload speed. It is awful!
