DCMiller's avatar
DCMiller
UPnP issue when using ORBI and a Nighthawk hotspot
So I believe that I am dealing with a rather unique circumstance. I am currently using a NETGEAR Nighthawk mobile hotspot (MR1100) in conjunction with an Orbi system. Here are the specifications of the Orbi
ardware Version    RBR50
Firmware Version    V2.3.5.30
GUI Language Version    V1.0.0.360
Operation Mode    AP
 I just recently switched the Orbi to AP mode due to a double NAT issue that was causing issues when browsing or streaming. I am using the Nighthawk with a AT&T tablet plan with unlimited data with this. (I know its not a perfect set up, but rural american really needs some internet options that don't have me jumping through loops)
There is a setting in the Orbi when in router mode to enable UPnP but once in AP mode it is unavailible. I have tried turing it on and returning the Orbi to AP mode but to no avail.
I am not sure exactly what other information to include but I am happy to provide all I can.
  • FURRYe38's avatar
    When in AP mode, there are various features like uPnP which are disabled. The uPnP function at this time would come from the main host router upstream from the Orbi. Two uPnP features on two different routers won't work, thus reason of disabling it while in AP mode. Did you try the RBR in router mode using the main host routers DMZ?
    • DCMiller's avatar
      DCMiller
      Thanks for the prompt response.
      Bare with me, I am currently getting as familiar as I can with networking and I'd rather not waste all of your time asking questions that google can answer.
      My understanding is the DMZ configuration would be forwarding the responsibility of acting as a router to the Orbi. For this I will need to access the current wireless hotspot through a browser. Just for clarification, will I need to save the IP address of the Orbi, disconnect it, reconnect to the Nighthawk LTE hotspot as a stand alone connection, log into the network settings using its IP and then set the DMZ parameters to forward to the Orbi's IP then reactivate the Orbi to operate in router mode?
      I know those may seem like simple questions but I just want to make sure I have a decent grasp on exactly what I should be doing.
      Also, to view the IP address of the Nighthawk LTE hotspot, do I need to do anything in particular?
      • FURRYe38's avatar
        Yes.
        Not that I know of. Refer to the hot spots user manual for it's web page access information and configuration.
