My Firmware Version is V4.6.5.8_2.0.54, and I have a v3 before, with both I had the upstream light blinking all the time. There is no connectivity issues, so, internet works fine, even with the v4 looks like better than before, but I see the upstream light blinking all the time and it's pretty annoying.
Download and upload speed are fine, I don't have disconnections, the Xfinity techinitian came to my house around three weeks ago to verify the signal, and line, and he said that there was no problems. No splitters between the modem and ISP service box, and several reboot (Power OFF the modem for more that 2 minutes and them back ON), and factory resets didn't change the current blinking light.
Cable connection:
| Startup Procedure |
| Procedure | Status | Comment | | Acquire Downstream Channel | 507000000 Hz | Locked | | Connectivity State | Ok | Operational | | Boot State | Ok | Operational | | Security | Enabled | BPI+ | | IP Provisioning Mode | Honor MDD | honorMdd(4) |
| Downstream Bonded Channels Partial Service |
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectable | | 1 | Locked | QAM 256 | 17 | 483000000 Hz | 3.7 dBmV | 36.6 dB | 8 | 0 | | 2 | Locked | QAM 256 | 18 | 489000000 Hz | 3.7 dBmV | 36.6 dB | 3 | 0 | | 3 | Locked | QAM 256 | 19 | 495000000 Hz | 3.7 dBmV | 36.6 dB | 8 | 0 | | 4 | Locked | QAM 256 | 20 | 507000000 Hz | 3.5 dBmV | 36.3 dB | 22 | 0 | | 5 | Locked | QAM 256 | 21 | 513000000 Hz | 3.2 dBmV | 36.6 dB | 0 | 0 | | 6 | Locked | QAM 256 | 22 | 519000000 Hz | 3.2 dBmV | 36.3 dB | 0 | 0 | | 7 | Locked | QAM 256 | 23 | 525000000 Hz | 3.2 dBmV | 36.6 dB | 0 | 0 | | 8 | Locked | QAM 256 | 24 | 531000000 Hz | 3.2 dBmV | 36.3 dB | 0 | 0 | | 9 | Locked | QAM 256 | 25 | 537000000 Hz | 3.2 dBmV | 36.3 dB | 0 | 0 | | 10 | Locked | QAM 256 | 26 | 543000000 Hz | 3.2 dBmV | 36.6 dB | 0 | 0 | | 11 | Locked | QAM 256 | 27 | 549000000 Hz | 3.2 dBmV | 36.6 dB | 0 | 0 | | 12 | Locked | QAM 256 | 28 | 555000000 Hz | 3.0 dBmV | 36.6 dB | 0 | 0 | | 13 | Locked | QAM 256 | 29 | 561000000 Hz | 3.2 dBmV | 36.6 dB | 0 | 0 | | 14 | Locked | QAM 256 | 30 | 567000000 Hz | 3.0 dBmV | 36.3 dB | 2 | 0 | | 15 | Locked | QAM 256 | 31 | 573000000 Hz | 3.2 dBmV | 36.3 dB | 0 | 0 | | 16 | Locked | QAM 256 | 32 | 579000000 Hz | 3.2 dBmV | 36.3 dB | 0 | 0 | | 17 | Locked | QAM 256 | 33 | 585000000 Hz | 3.2 dBmV | 36.6 dB | 0 | 0 | | 18 | Locked | QAM 256 | 34 | 591000000 Hz | 3.2 dBmV | 36.3 dB | 0 | 0 | | 19 | Locked | QAM 256 | 35 | 597000000 Hz | 3.0 dBmV | 36.3 dB | 0 | 0 | | 20 | Locked | QAM 256 | 36 | 603000000 Hz | 3.7 dBmV | 36.3 dB | 0 | 0 | | 21 | Locked | QAM 256 | 37 | 609000000 Hz | 3.7 dBmV | 36.6 dB | 2 | 0 | | 22 | Locked | QAM 256 | 38 | 615000000 Hz | 3.5 dBmV | 36.6 dB | 5 | 0 | | 23 | Locked | QAM 256 | 39 | 621000000 Hz | 3.5 dBmV | 36.3 dB | 7 | 0 | | 24 | Locked | QAM 256 | 40 | 627000000 Hz | 3.2 dBmV | 36.6 dB | 4 | 0 | | 25 | Locked | QAM 256 | 41 | 633000000 Hz | 3.2 dBmV | 36.3 dB | 15 | 0 | | 26 | Locked | QAM 256 | 42 | 639000000 Hz | 3.0 dBmV | 36.3 dB | 12 | 0 | | 27 | Locked | QAM 256 | 43 | 645000000 Hz | 3.0 dBmV | 36.6 dB | 0 | 0 | | 28 | Locked | QAM 256 | 44 | 651000000 Hz | 2.7 dBmV | 36.3 dB | 0 | 0 | | 29 | Locked | QAM 256 | 45 | 657000000 Hz | 2.4 dBmV | 36.3 dB | 0 | 0 | | 30 | Locked | QAM 256 | 46 | 663000000 Hz | 2.5 dBmV | 36.6 dB | 0 | 0 | | 31 | Locked | QAM 256 | 47 | 669000000 Hz | 1.7 dBmV | 36.3 dB | 0 | 0 | | 32 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| Upstream Bonded Channels |
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power | | 1 | Locked | ATDMA | 1 | 5120 Ksym/sec | 16400000 Hz | 40.8 dBmV | | 2 | Locked | ATDMA | 2 | 5120 Ksym/sec | 22800000 Hz | 41.5 dBmV | | 3 | Locked | ATDMA | 3 | 5120 Ksym/sec | 29200000 Hz | 42.3 dBmV | | 4 | Locked | ATDMA | 4 | 5120 Ksym/sec | 35600000 Hz | 43.3 dBmV | | 5 | Locked | ATDMA | 5 | 2560 Ksym/sec | 40400000 Hz | 43.8 dBmV | | 6 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 7 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 8 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| Downstream OFDM Channels |
| Channel | Lock Status | Modulation/Profile ID | Channel ID | Frequency | Power | SNR/MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords | | 1 | Locked | 3 | 48 | 688000000 Hz | 1.2 dBmV | 35.3 dB | 1108~2987 | 0 | 0 | 0 | | 2 | Not Locked | 0 | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0~4095 | 0 | 0 | 0 |
| Upstream OFDMA Channels |
| Channel | Lock Status | Modulation/Profile ID | Channel ID | Frequency | Power | | 1 | Not Locked | 0 | 0 | 0 Hz | 0.0 dBmV | | 2 | Not Locked | 0 | 0 | 0 Hz | 0.0 dBmV |
| Current System Time: Fri Nov 5 09:39:50 2021 |
| System Up Time 2 days 00:34:38 |
Latest test result (9:20 Nov 5, 2021)
DOWNLOAD UPLOAD
1023.52Mbps 24.11Mbps
Thoughts?
