ChezStevens's avatar
Aug 09, 2022
Use ORBI LBR20 LTE in failover to Netgear LAX20 LTE router
Hi folks,
Hope you can help. Due to lousy internet connection using French telecom provider (10mbps down, 1mbps up) we now use Free Sim data plans in both Orbi LBR20 & Netgear LAX20 LTE routers (210Gb allowance for both, giving 420Gb total).
My question, before playing (interpretation: screwing up) with system: Can I use my Netgear LAX20 LTE router as primary, with Orbi LBR20 connected in Failover mode? My Orbi setup, LBR20 plus 3 RBS50, works well but I would like to unify the total 420Gb data plan into our house wide system. Thank you, Vern
  • plemans's avatar
    Aug 09, 2022
    As far as I can tell, failover will switch when the connection stops working. So if your isp stops your connection at 210gb, it should work. If they step it down to "low data rate" but the connection still works, then I'm not sure if it'll switch over.
    Again, neither device is load balancing so there isn't a way to set it in the settings to split the 2.
    And I dont have either device to see if there's a way to set them to disable after a certain amount of data is used.
    A bit funny how the lax20 gets the much lower speeds. Have you tried swapping sim cards? maybe one was provisioned different.
  • plemans's avatar
    You can do it as both devices have failover mode.
    but failover isn't load balancing. If your telecom shuts off your data when you hit 210gb, then it should failover to the other device if programed that way.
    • ChezStevens's avatar
      ChezStevens
      Tutor
      Hi Plemans,
      That is all I want to happen, Netgear LAX20 uses its 210Gb servicing my home network (thru the Orbi LBR20 & sats); then LBR20 uses its 210 Gb. More than ample for our needs. Interesting to us, the Netgear LAX20 gets 30down7up, the LBR20 (pointing at same masts) gets 185down,15up.
      kindest regards from a very sultry (read sweaty) SW France,
      Vern
      • plemans's avatar
