JCar's avatar
JCar
Used Orbi transfer ownership
I purchased an AC3000 second hand. The previous owner said they forgot their netgear login info I would need to reach out to support. The satellite is registered to me.
How do I gain registration on the router? I have gotten zero response from netgear support.
    • JCar's avatar
      JCar
      Hello @plemans,
      So just to clarify there should be no security risks with the fact someone else has it registered? I didnt want to set it up until i got some sort of reasurance on that part or got it registered to my name.
      Thanks for the assistance.
      • plemans's avatar
        No.
        Just do a factory reset and reinstall and you should be good.
