macjohn
Dec 04, 2018Guide
using 2.4 vs 5 Ghz..
Hello,
I have a few devices which operate only on the 2.4 Gz band...how do I ensure that these devices will only connect via 2.4 and not try to
connect via 5 ? None of them are showing up as connected to my wi-fi network because they seem to always try to connect to 5.0.
Thank you for any help.
If the devices only support 2.4Ghz and don't have any 5Ghz hardware support, then they will only see the 2.4Ghz radio.
Try setting manual channel 1, 6 or 11 on 2.4Ghz.
Try setting WPA and TPIK first then try WPA2 and AES only. You can disable WPA temporarily to see if your devices will connect here.
You can try setting the power for the 5Ghz radio from 100% to say 25% temporarily if you think this might help.
- ekhalilMasterA device that has single band support (2.4 GHz) will never try to connect using 5 GHz band.
- macjohnGuide
Hello,
I appreciate everyone's replies and suggestions; I will try them...
If my devices (Nest Protect CO/smoke alarms) are not connectiing to my wireless network and they are only able to via 2.4Gz band why won't they show up on my list of attached devices ? They can talk to each other, but just won't show up on my network.
- ekhalilMasterThis can be caused by that your Nest Protect devices were previously connected to another router with the same SSID?
Please check this:
https://community.netgear.com/t5/Orbi/Orbi-and-Nest-Protect-issues/m-p/1159980/highlight/true#M857
