gelliott1's avatar
gelliott1
using apple Remote Desktop with orbi and satellites
hi thre, can anybody tell me how I enable apple remote desktop on an orbi ? I see in my remote desktop window (apple software) that for screen sharing port 5900 is greyed out, and remote management 3283 is greyed out. Both macs are running latest Mojave, different networks. Can anybody talk me through the steps to enable this so it works? Im not really familiar with port forwarding so as much detail as possible would be really helpful thanks.
    • gelliott1's avatar
      gelliott1
      the latest firmware is laoded....i ipdated it yesterday...
      there is no ISP router, its gets a wan straight from the wifi antenna on the top of my house that goes to a nearby farm. I can coinnect with screen sharing but prefer to use Apple Remote Desktop
      • FURRYe38's avatar
        Ok, just checking to see if there was a router infront of the Orbi router already. Your fine here.
        Please try the suggestion provided by ekhalil
      gelliott1
      what does this mean from the link you sent please?
      Specify the desired external port number
      ("External port range"),
        gelliott1
        also do i need to fix the IP address of the target system? I reserved it but still shows as the old one in the attached devices list
