dangitzin
Feb 13, 2018Aspirant
Using Ethernet ports on the Satellite
New to the Orbi system. So the satellite has Ethernet ports... My question is, will I be able to connect a pc, console, or anything for that matter in the ports and have it be supplied with internet? ...
- Feb 14, 2018
Yes, you can use it as you describe. I have my Hue hub plugged into one of my satellite ports and have, in the past, had my laptop connected for testing puposes.
dangitzin
Feb 14, 2018Aspirant
Thanks for the responses! I'll be cleaning up my set up this weekend(satellite is just sitting in the hallway upstairs).
