u7mg0
Nov 28, 2018Follower
Using existing network name
trying to understand the set up. i plug the Orbi main unit to my existing cable modem with an ethernet cable. i then want to use my existing network name and password so i don't have to reprogram a...
Nov 28, 2018Guru - Experienced User
Of course you can use same SSID name and PW as before.
