Henrykoh
Aug 31, 2017Follower
Using genie to enable guest wifi
After i updated the netgear orbi to 1.12.0.18 , im not able to enable guest wifi using the genie app. It says router does not support guest wifi. Before i update to this latest firmware it's working well. Please help.
- Bing-StrollerLuminary
My Genie app updated to a new version last night
Version 3.1.36 dated 29 Aug 2017
It might be worth checking if you are on the latest release.
- BillYoungLuminary
Bing-Stroller:
I am updated to the latest version of the Genie app on my cell phone: 3.1.36.
Every time I try to access the Guest WiFi, it tells me that "This router do not support guest WiFi."
Now if I use the Genie app on my PC, which is version 2.4.26, it accesses the Guest WiFi just fine.
So it sounds like to me there is a bug in the cell phone version of the Genie app.
BillYoung
- BmMdlkTutor
Same exact thing for me.
- OrbiManLuminaryYou have to use the Orbi app
- BmMdlkTutor
That's it. I uninstalled Genie and installed the Orbi app and Guest Wifi controls work perfectly. I was not aware of the Orbi app until now. Thanks!!
