Kmassimo's avatar
Kmassimo
Using Netgear and Orbi modems
I have NETGEAR - 32 x 8 DOCSIS 3.1 Cable Modem less than six months old. I now need a new router and I'm looking at the Orbi whole home mesh with the modem built in. Can I use both? Is there any benefit to having 2 modems? How would I connect them.
i am using iMac, iPad, iPhone with Spectrum.
TIA
  • FURRYe38's avatar
    Which model NG modem do you have?
    No, it's one cable modem per one coax line that comes from the ISP. You can't use both at the same time.
    • Kmassimo's avatar
      Kmassimo
      CM1000
      Is there another router I should consider? One that would work with my current modem?
      • FURRYe38's avatar
        The CM1000 is a good modem. You can keep it and connect up a Orbi RBK50 or 850 series system to the modem.
        Kmassimo wrote:
        CM1000
