mesh_it_up
Nov 25, 2019Aspirant
Using Orbi in another country
Are there any geographic limitations to using Orbi RBK53 bought in the States? For example, I want to set up my parent's house in Ukraine with Orbi - will I be able to do that? Reason I am asking...
CrimpOn
Nov 25, 2019Guru - Experienced User
People report purchasing Orbi in the US and installing in many other countries. The key to success is to use telnet to change the Region Code choices and select the one that most closely matches Ukraine. (Other countries have different restrictions on which WiFi channels are available and what power levels are allowed.)
The other issue would be which languages the Orbi web interface supports. The Orbi "app" is cute and very "app-like", but many of the Orbi features cannot be managed using the app. If you pull down the menu in the upper right corner, it shows the languages available. I see about 4-5 with Cyrillic characters. Might be a different list when the Region code is set different from US, although it seems unlikely.
If you already own an Orbi, it would be worth investigating before purchasing another. i.e. change the existing Orbi Region choices, pick the one that matches (Eastern Europe?), and see what language choices there are.
- mesh_it_upNov 26, 2019Aspirant
Thanks, CrimpOn
Web UI language should not be an issue, it will be me who will be setting up the network.
The regional settings is a great recommendation. I found the following instructions on it https://community.netgear.com/t5/Orbi/Changing-Orbi-Region/td-p/1546663
I will be sure to follow them
